Clutch housing washer
malcolm
I removed the clutch housing on a Sherco ST 125 (2015) to in order to replace the gear selector spring. I have done this and put everything back together but am left with a washer and am not sure where it goes. It has an outside diameter of 30mm, an inside diameter of 17mm and is about 1mm thick?
