Montesa 349 Amal carb.
netley
Hi, Just giving the carb a good clean. It's an Amal L2627 410. The only info on the correct jets etc. for the 349 are for an L2627 216 and I have slightly different ones.
Info taken from this site says;
Amal carb as per MH359 manual
Make;Amal
type;L-2627/216                             Mine; L-2627/410
diffuser diameter;27                                 27
Main jet;145                                           150
Low speed jet;20                                     20
Gas valve;no.4                                        ?? what's this ??
sprayer;107                                            106
position needle; 2a (2B1)               Middle groove of 5        2B1
It looks like I can get all I may need direct from Amal uk. Should I go with what the manual says or stick with what I've got as it's a different model?
The slide looks worn so I shall replace that.
Thanks for looking.
Neil
The gas valve is the slide.  You have a small difference in needle jet (sprayer) and main jet.
I was typing this as suzuki's reply came in and was about to say see how it runs before changing anything. But I am not familiar with the difference in carb types though the numbers might indicate that yours is intended for a four stroke, but as it has a pilot jet then perhaps not.
Make;Amal
Main jet;145                                           150
Low speed jet;20                                     20
sprayer;107                                            106
Thanks for looking.
Neil
Hi Neil, I think that example you posted is actually a 416 not 216. Regardless, here is a couple of exploded view diagrams I have found for 349 carb's. The 1st one is for a 406 carb with a part number of '5162.00101' possibly one of the 1st 349 versions, the 2nd pic is for a 416 carb with a part number of '5162.00104' definitely intended for models 51M24424 and upwards and more likely suited to the last of the 349's, such as 349/4, MH 349 and 350. Hope this info helps.
PS: Can only upload the 406 in this post, the 416 will be in next post.
Thanks, Those are great !
I have priced up replacing all the jets, gaskets etc. and it comes to 46 GBP (76 Austalian dollars). I recentley re-built a Bultaco which had the wrong carb on and replaced it with a new Mikuni from the same company, which works great. A new and ready jetted to suit the Montesa Mikuni would be £157 (259 Australian Dollars).
Seeing as the one I have is getting on a bit I'm thinking of doing the same. Any thoughts?
Neil
18 minutes ago, feetupfun said:
The 26mm OKO I bought for my 348 works a treat, came with a new rubber connector, fitted without modification and cost $200 australian dollars including freight
Where from !!!!!
  • 3 weeks later...
