betasweden
2017 4T miss fire on high RPM
36 posts in this topic
Hello,
Seeking help with this issue.
My 2017 300 4T is running great. Except for one thing.
On really high RPMs the engine misfire. Like an Enduro 4T.
Really annoying when you need to have high RPMs on a big step with short run up.
Is in any kind of "RPM stop" on them?
I have changed, jets etc..
Thank full for all help!
Share this post
Link to post
13 minutes ago, betasweden said:
Hello,
Change the jets again. Changing the jets from what used to work fine if you develop  a problem is one of the avenues to go down.
Share this post
Link to post
Hello
It has always been this problem. Dont think it has to do with the jets. Dose not sound like that.
Share this post
Link to post
 The standard or the factory?
Share this post
Link to post
Sorry, Standard 2017.
Share this post
Link to post
The std exhaust does not breath very well. My son has an `15 with a header pipe and the factory exhaust. I would start with the a new muffle . What jets did you go to.?
Share this post
Link to post
What is an header pip? I have now an Bosi exhaust. But this problem was even before i changed..
Think Main is 137,5 right now.
But this issue on high RPMs has been sens new :(
Share this post
Link to post
A 137 is pretty big, what pilot and elevation are you at. You have the complete Bosi exhaust?
Share this post
Link to post
Yes, i know... But i did go bigger and bigger. And stoped at 137. Could probably go back a bit. But runns ok now. And its not that fun to change on the 4T..
 No, Bosi only have an exhaust pip for 4T. Not full..
But should not misfire on high RPMs any way?
Share this post
Link to post
14 minutes ago, betasweden said:
Hello
Did the problem start after you changed the jets or before......did you change the jets because you had them in the garage so you thought you would try them out.
Share this post
Link to post
As i stated, it has always been this issue. And the bike comes "lean" from factory. So you need to change from the beginning. Dose not run good at all from Factory.
Share this post
Link to post
Maybe you need to set the valves up to service limits or mess about with the jetting some more.
Share this post
Link to post
The bike is almost new.
But is there any RPM stop on them?
Share this post
Link to post
If you had the problem right from when you purchased it then it must be the way they are supposed to be.
I know that Beta probably do not know if there is a rev limiter on them as they made it, but it should not misfire
At the last trial I was at there was a rider on a Beta 4T that kept back firing so perhaps its just a quirk of those engines.
Edited by oni nou
Share this post
Link to post
 Yes, I think you are right that you are hitting the limiter. Beta used to sell a race kit for the 4T. Cam, valves and a hotter ignition. Supposedly the Factory model has these. Talk to your Beta dealer/importer and see if it is available. I have ridden one with these mods and with higher compression, it was a monster of a bike. And the owner was one of our top riders. Very fun machine Good luck.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
