Rev 3 front spoke
diesel2607
Try Beta UK.part no 27-241192 size 3x254c 169
                                 27-241193        3x256c 169
                Nipple       23-10100
or here.
http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+3x254+Beta&Id_Article=632
http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+3x256+Beta&Id_Article=633
http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+nut+3+mm&Id_Article=3972
Edited by bilks
It's just the same as removing a bicycle tyre (if you know how to do that) - just more effort required and correspondingly bigger tyre levers. There are lots of videos on youtube showing this - mostly rear tyres though, which are tubeless (I just did my rear). I got a pair of cheap levers from eBay which came with some useful plastic rim protectors. Warning - although perfectly strong, my levers had a few rough edges so I filed them off before use. You will also need some tyre soap to make it easier - many use fairy liquid (I did!) but there seems to be quite a debate about its long term effects on alloy rims. Careful not to nick the tube - a very small amount of air inside when re-fitting the tyre can help avoid trapping it. Good luck
Mark
Edited by markparrish
spelling tyre!
                Nipple       23-10100
or here.
This part no comes back with a spoke for a techno will this same spoke fit 2005 rev 3
