pwadz
Air Cooled Mono 2 stroke mix????!
Advise needed please ,just starting out in the world of Trials with a  Fantic 303 ...
Confused about oils ...mineral or Synthetic ?  Mix ratios?
Any suggestions would be gratrfully recieved
Share this post
Link to post
Personally I would use fully synthetic only and at 50:1 but.....32:1,   40:1 , 50:1    any one of those will work take your pick......if you are are the worried type mix at 32:1 if not then go 50:1 or wait for some one elses post that says mix only semi synthetic at 25:1.
normally on an aircooled trials 2t you would not mix at less than 50:1...[.eg a mix of 60:1]..........IMO.
Edited by oni nou
Share this post
Link to post
Manuals for air cooled bikes usually recommended 32:1 but that was in large part due to the variability in oil and fuel quality and a margin of safety built into the recommendation. If you have access to a good quality synthetic oil 50:1 will work fine. I ran Bel-Ray MC-1 for decades at 50:1 in everything from Maicos to Bultacos to Can-Ams (Armstrong) with never an oil related failure. Now having said that I assume you are riding the mighty Fantic like a trials bike and not flogging it like it was a short legged MX bike. I've seen that done and it causes "unusual" wear in a trials engine.
Share this post
Link to post
The recommended ratio by Fantic back in the day on a then ordinary oil was 50 to 1 (don't know about the 303 but earlier models had the measure in the filler cap).  No need for full synthetic really as any oil nowadays should be superior to that of 35 years ago.
Share this post
Link to post
5 hours ago, pwadz said:
I was thinking stick with mineral oil.... is castrol 2t a good one or is there a more superior mineral based to use?.
I was thinking you would say that ....if you can find some mineral 2t oil then try  32:1 its your perfect mix. If Castrol cannot make a decent oil by now after all these years in the business then who can.
Edited by oni nou
Share this post
Link to post
40 years ago Fantic recommended run with mineral oil at 2% (50:1)
now i race the 240 and 300 at 1.2% (80:1)  with synt oil (Motul 800-710 or other brand )  without any unusual wear, i tell you this because i have demounted my engine last year and the interior of the engine was perfect, so i think it's not necessary run at high percentage
Share this post
Link to post
Its a great STORY but running at 80:1 in an aircooled engine in Italy where it is probably warmer than it is in the UK......just not possible...... your  engines are definitely ruined,I should have another look and rebuild them then use a bucket full of oil to a cup full of petrol.
Share this post
Link to post
i have some trouble to translate (sorry) but i understand that you think it's not possible to run at 80:1  ?
i ride my Fantic trial from years only in classic competition and trial practice, usually 10 liters gasoline 100 octane with 140 cc of sinthetic oil but last year i cheked ours engine and discovered inside a lot of deposit on pistons and head, and watching the bearing, pistons and cylinders they were full covered of oil (like a four stroke) so i decided (after suggest of my mechanic) to reduce the oil at 80:1 (our Beta evo run at 90:1)
consider that ossa and vertigo run at 120:1 and they run well, Beta enduro 250/300 2t self mix run from 0.8% to 1.6%
this is what really happen here in Italy in my garage and see with my eyes, and yes here is very hot  ... but i never ride my bike on street and at high rpm
Share this post
Link to post
Alberto thankyou for your reply.......It is very good,I like it very much.
Share this post
Link to post
I run all of my 1980 Fantics (200's, 125, 201, 241 and 301) at 70:1 with fully synthetic (Castrol XR77) and have done for years with no issues at all. 50:1 is way to much oil if you're using synthetic and I shudder to think how bunged up your pipe (!) would get with 32:1!!!
Share this post
Link to post
You need to talk to dadof2 he says that even at 25:1 your exhaust will stay whistle clean with quality oil and fuel plus correct jetting and set up..................?
You may have seen a post on here about UK Vertigo bikes running at 200:1 this advice coming from the UK importer and obviously with the knowledge of the Factory.
Edited by oni nou
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
