Sign in to follow this
gleiwitz
Dellorto petrol pump - issue
Hello,
I would like to ask for your help before I order a new petrol pump. Maybe I missed something during my investigation.
The problem with my Sherco St 300 from end of 2013 is that the carburetor does not get fuel or gets too little.
I first checked the vent of the fuel tank - one-sided valve ok,  fuel hose - ok,  fuel tap - ok.  Just to be sure I started the engine with the unscrewed fuel tank to be sure the reason was not to vent the fuel tank
I disassembled the fuel pump -  cleaned - I have not seen any signs of wear or damage.
I started the engine. After a while the fuel stopped flowin. I disconnected the fuel lines and fed the fuel directly to the carburetor using a syring. From disconnected fuel supply line from the pump to carburetor fuel does not flow. During engine operation in a normal situation petrol pump should pump fuel  ?
Do you have any ideas what else should I check?
Edited by gleiwitz
Share this post
Link to post
43 minutes ago, gleiwitz said:
Hello,
I first checked the vent of the fuel tank - one-sided valve ok,  fuel hose - ok,  fuel tap - ok.  For sure I started the engine with the unscrewed fuel tank to be sure the reason was not to vent the fuel tank
Pump works by vacuum  created by piston downstroke  so check the vacuum pipe that goes from the carb intake rubber area to the pump itself.....if it has a cut/hole in it or is trapped/pinched somewhere then you have no vacuum and therefore no pumping will take place.
Share this post
Link to post
Thank you very much for the reply!
I checked the hose only visually. I did not dismantle it.  I checked its position so nowhere is trapped / pinched. I will check tomorrow whether there are any holes or cracks.
Apart from the vacuum pipe, something may be the reason for not creating a pump-induced depression?
Share this post
Link to post
Yes a hole or non sealing of the diaphragm in the pump itself.
Share this post
Link to post
 Thank you very much for your help.
I will check it and if vacuum pipe will be ok  then I will order a new pump because I am slowly losing patience :)
Share this post
Link to post
Hope you find the problem soon.
Share this post
Link to post
Problem solved :)
The cause of the problem was vacuum pipe. It was not visible but when  I disassembled the vacuum pipe I noticed that hose/pipe clip was badly mounted at the very end which caused the hose to deform and consequently leak / catch the air.
 I mounted a new vacuum pipe on the lef side of carburetor where I my opinion is more space and pipe will not bends
Thanks a lot for your help.
Share this post
Link to post
17 hours ago, gleiwitz said:
Today I was practice and unfortunately the pump stopped working again :( I got upset and ordered a new pompe. I hope this will resolve the problem definitively.
 Voodoo type problems.
Edited by oni nou
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
