sprocket62
Bantam trials info needed
Hi members.  will someone tell me the best spark plug to use in a bantam 175 for trials use?
and the best petroil mix using fully synthetic 2 stroke oil?  ???ml  per 5 litres petrol.
Paul
Share this post
Link to post
what head is fitted D7, D14, B175, Todd?
B7ES plug & 30:1 Oil?
like brownie001 says, depends on mods :thumbup:
Edited by suzuki250
Share this post
Link to post
Bit late but only just seen it. My Bantam has D14 engine with B175 head and runs fine on either B6ES or B7ES, Petroil mix on full synthetic 40:1
Share this post
Link to post
Hi,
mine is a Drayton 185cc running a standard B175 centre plug head with B7ES plug.  50:1 petrol oil mix using putoline.
PVL ignition set 1.1mm BTDC
main jet 120
pilot with 2 rings
105 needle jet
NO.3 slide
seems to work fine for me.
Share this post
Link to post
one thing you ll find for bantams is that no two are jetted the same. however buy a set of jets and much and i mean much time later you  can have a bike that runs as smooth as poured cream that ll pick up clean from stopped dead on a slope.. no big bang of power they were commuter bikes remember.. but enough to haul evenbig boned fellas around more than adequately.. mine is std b175 on pvl with drayton exhaust used 50:1 for last 5  years
Share this post
Link to post
On ‎20‎/‎06‎/‎2017 at 9:55 PM, hencam said:
Hi,
main jet 120
pilot with 2 rings
105 needle jet
NO.3 slide
Thank you... perfect.  by my working out that's 100ml's putoline to 5 ltrs petrol.... did 120/130 and it runs ok but oil up after running and job to start again, clean plug and away she goes again.  much appreciated.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
