Flywheel Weight Yes Or No?
trialsscotland
I have no practical knowledge of flywheel weights, but thinking through the theory leaves me sceptical. While the weight will significantly increase the inertia of the moving parts of the engine, when you add in the weight of bike and rider it will be largely insignificant. Now someone, tell me I'm wrong.
The standard 300 has a flywheel weight fitted on the back of the flywheel (see picture of when we removed ours), so not easy to see unless you remove the flywheel.
Some riders remove the weight to get faster response, so maybe ask the previous owner if they removed it.
