2003 Beta Rev3 How strong front brake should be?
b182
Hi guys. I'm wondering how strong should it be. I think my is a little too weak. It doesn't stop the wheel immediately. When i try to do stoppie it's very hard to block the wheel. It's bleed correctly (I think so). I even cleaned disc with solvent. I don't know is that ok that i've to use a lot of force. Any suggestions.
Yes, I know that brakes are designed to get hot and cold but I also know that fast cooling of very hot brake can bend the disc due to temperature expansion of metal. But if You say so I'll try that way. Thanks
Thanks. I'll try bleed it again because the lever in not hard( i dont know how to say it in english). The lever works like its rubber inside of the mastercinder. In my previous bike (ktm) it was much harder or stiffer whatever.
What's more when i was checking the brake system I accidentally spilled some brake fluid on brake pads. I cleaned them with some thinner or something but maybe theres an problem. Is there the other way to clean them up better or I have to buy new ones?
Edited by b182
