Gas gas identification
stilly36
A little help please. I have a gas gas 300 txt pro 07. As I was told. Can any 1 confirm this off the num. Vtrgg3002f0740086
Also can any 1 tell me how much oil for a oil change. Thank you all very much.
Edited by stilly36
550cc from empty but use your sight glass until it's half way up.2007 had a black frame.
2004 and newer (after July 2003)
Example: VTRGG 3002 D093 9955
VTR = International manufacturers code. VTR = GasGas
GG =Trial model (Company code to identify model EC = Enduro & MX, FS = Four Stroke, WD = Quads)
3002:
30 = 300 model.
02 = (02 = year of Europe homogulation N/A USA)
D093:
D = 2003 ALPHA CODE FOR MODEL YEAR.
09 = Manufacture month (9TH month) September.
3 = Year of manufacture 2003.
9955 = sequential chassis number. (9,955th built in this year.)
“Alpha” model year codes Model engine size codes
D = 2003 J = 2008 12 = 125cc
E = 2004 K = 2009 20 = 200 model (175cc)
F = 2005 L = 2010 25 = 250cc
G = 2006 M = 2011 28 = 280 model (272cc)
H = 2007 N = 2012 30 = 300cc
Edited by bilks
3002:
30 = 300 model.
D093:
So I am thinking it's a 2005 250cc now. Am I correct. Unsure about 300 cc
3002:
30 = 300 model.
D093:
3002:
30 = 300 model.
D093:
Vtrgg3002f0740086
I would say based on the table above your VIN is for a 2005 model 300cc (also look on the cylinder flywheel side by the exhaust and you should see 30 stamped/cast into it)
3002 = 300 model with the 02 year of Europe homogulation
F = 2005
07 = manufactured in July
4 = manufactured in 2004
0086 = 86th bike made
As for gearbox oil, the Pro engine uses much less than the previous model engine.  Takes approx 380cc, but of course watch the sight glass on the clutch cover and fill it to halfway or just above halfway.
Which oil to use? there is a wide range of opinions on that.............
Edited by zippy
  • 6 years later...
34 minutes ago, wayno57 said:
Can someone tell me motor size? VTR GG 1694 10 94 0115
@wayno57 according to that it is a 163cc motor  which should be a 1994 JT 160 , or called a 200 by some people , look on the cylinder it may be marked on there although it could have been converted to a 125cc at some stage in its life as those two capacities share the same crank/conrod assembly. If you want to be sure then drain the coolant and take the head off and measure the piston diameter , if its a 163cc it will be 64mm dia , if it is a 54mm it is a 125cc , the gearbox/clutch casings  look the same on all the variants so it could have had a complete motor change at some point and be a 250 or larger , as i said  you will know by the piston diameter.
Edited by Tr1AL
Thanks. Bought this from a guy that told me it was a "95" 260cc. Not that the size matters for riding, being off a trials bike for quite some time (35 yrs) just want to bang around in my yard and woods. Usefully info for finding parts if needed.
If it actually is a 163cc then if it is tuned nicely and the piston and cylinder etc is in good order then it will have plenty of power for most mid weight riders , a better bike IMO than the earlier PRO models. Have fun.
