Sign in to follow this
Followers 0
thai-ty
chain lube - sandy conditions
23 posts in this topic
Hi, coming from having road bikes all my adult life, and being a m/c mechanic and machinist, I know about chains and lube.
But, now I've got into trials bikes as well, i'm in a dilemma about lubing the chains on my two ty250 mono's. Where I ride, the soil is almost like a lime, sandy condition. Whatever is put on the chain, either proper aerosol Silkolene chain spray, or g/box oil from an oil can spout just on the rollers, it's just like flies being attracted to sh... Anything will attract the sand.
So. lately I've been running the chains dry, no lube and giving them a brush down post ride. At 12 quid for a new length of brand name chain locally, this seems my best option.
Any views, opinions, comments? What's better? Right or wrong?
Share this post
Link to post
Get some dry chain lube.
I use this
1 person likes this
Share this post
Link to post
Yes I stopped oiling my chains years ago and just spray them with WD40 and actually found that my chains and sprockets do not wear as quickly as previously when I used to use the sticky gloop aerosol type chain lubes.......by the end of a trial with sections running through streams/creeks there was no lube left on the chain anyway.
Like you say if you lube your chain in sandy conditions the lube is like a magnet holding the particles onto the chain and helping  to form a nice abrasive grinding paste.
Edited by oni nou
2 people like this
Share this post
Link to post
WD 40 here as well. I will pressure wash the chain clean, hose it with wd40 after blow dry, let it sit overnite and it is ready to go. I only reapply in a extremely muddy trial as a mud repellant. don't like it wet and slinging oil.
1 person likes this
Share this post
Link to post
Would WD 40 not attract sand?
I'm thinking completely bone dry and just replace with a new one every year.
Share this post
Link to post
WD is to ward off the rust.... Britain has a water content in the air and the ground of about 99% so it is essential here or the chain would rust away before it ever got a chance to wear out. Just run it dry......I would or get some dry lube to use as previously mentioned,...you can make your own dry lube aerosol by using an old aerosol air freshener can that is completely empty and save £6 or whatever....just point the nozzle at the chain and spin the rear wheel round while it is up on a box stand .....the best thing is it never runs out and costs nothing.
Edited by oni nou
1 person likes this
Share this post
Link to post
Excellent idea. Have you not thought about patenting this.
1 person likes this
Share this post
Link to post
I use WD40 on my bikes, every ride, come home, wash bike, clean chain and spray with wd40, wipe chain and swing arm with clean cloth and it’s ready for the next time. No more wear than using normal lube and chain and surrounding area are always clean. And a large can of WD40 is cheaper than a can of most chain lubes.
Share this post
Link to post
Now you metioned it ,its patently obvious...I should at least try.
1 person likes this
Share this post
Link to post
Wurth dry lube is great in the summer if you're not washing your bike on every outing.  Wurth also do a light oil spray that's like WD40 but with more oil residue left, which I like.
On my street bike I use WD40 brand chain wax, which would probably be suitable for any longer distance rides like if you're taking a road legal trials bike up into the Pyrenees or along the Florida Way or something.
Share this post
Link to post
Yes, but do you ride in sandy conditions?
Share this post
Link to post
As mentioned dry chain lube do the trick very well.
To WD40 you might look  up for what WD40 is mentioned to be: "Water Displacement perfected on the 40th try"
WD40 was invented by Convair for their Atlas rockets as a water displacement and corroion protection, and the 40'th try out of a mixture from peroleum and benzine finally showed very good results.
As a dry chain lube I personal use "PDL Dry Lube chainspray" which includes PTFE, before application I clean up the cahin from any existing minral oil as if there is something left the PTFE will not stick to the metal and then it's like using the chain without any lube.
Share this post
Link to post
can gt85 be used instead of wd40? ive been using putoline dx11 and the stuffs awful. makes a sticky mess on the swingarm and attracts loads of dirt.
Share this post
Link to post
Me too, never lube a chain on a trials bike...............a new 520 chain is only about £30
When the chain is goosed, chuck it away and buy another
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
