Reed valve shims, I dont have any?
mink_man
Hello,just in the last stages of my rebuild and ive been comparing what parts i had to what is on the parts catalog. Everything is order apart from i dont have reed valve spacers? Do i need them?
When i bought the bike it never had them either i must add.
Edited by mink_man
15 minutes ago, tony27 said:
What type of reed is fitted, if they are boyesen dual layer reeds they don't use stoppers. Any other brand on the standard reed block should require stoppers
V-force reed block doesn't have stoppers
Hello again Tony, I’m away from the garage but I took this picture today. Can you tell what it is from the picture?
Can only tell you that it's not a v-force reed, if it was the cage would be plastic, have no screws & your manifold would have the wings cut off
To tell whether you have boyesen reeds fitted to the standard cage will require a shot from the other side
