Sign in to follow this
chappo
SWM clutch springs?
I know there’s already chat and opinions from some time ago about these, but anymore up to date info from peoples experience since the last threads.
Thanks guys.
Share this post
Link to post
I have spent time effort and money on trying to make the clutch on my Swm work.  After changing the cam for the enduro model with the bigger balls, . as a last resort I have taken two springs out and it seems to be a compromise on a working clutch, easier action and not too much slip in the higher gears.
Hope
Share this post
Link to post
b40rt,
Thanks for that in depth reply, 😆😆😆😆
Only joking just asking before I make a decision.
Share this post
Link to post
@metisse
Still thinking about why you have no slightly advantage after the mounting the later enduro lever with the longer arm and the bigger balls,
as at least there should be a slight improvement to red and older yellow models.
Are you sure the base of the case is milled sufficient?
Share this post
Link to post
1 hour ago, chappo said:
b40rt,
Seriously, all the info you need is in the swm forum. Things to check - clutch springs, probably to hard. Clutch cable condition and routing. Clutch lever type. Clutch basket probably notched. What oil in gearbox ?
Share this post
Link to post
b40r,
Bought it as a renovation project for winter so haven’t ridden it in anger , just pottered up the drive twice on it before I stripped it. The clutch was difficult to say the least.
Im just rebuilding her, hence the questions.
Ive oiled the cable, cleaned the mechanism inside the clutch case and cleaned , decontaminated the plates.
Ive been advised to use a light gear oil, 75w!!!!
What do you use?
The clutch basket fingers are quite notched, will I be ok grinding the ridges off, I mean with a Dremmel and gently ?
Share this post
Link to post
On 07/12/2017 at 1:59 AM, chappo said:
b40r,
What do you use?
Routing of clutch cable is important, get a new one unless its very good.
Read about clutch levers, they make a huge difference.
I have been using fully synthetic 5:30 for about 2 years, works for me. Clutch will slip in high gears if you drop it, a compromise I'm willing to accept, more down to clutch springs rather than oil,l as it will also do this with other oils. Might be worth trying the "Beta Clutch Fix"
I have gently filed clutch baskets in the past, it will make an improvement, but try and source a good one.
Edited by b40rt
Share this post
Link to post
I ve got a pair of Domino levers, just put a full new set of springs in and a new Venhill cables on order.
The full set is on advice, also a good start point to work from.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
