Sign in to follow this
Followers 0
brownee
Not shutting off properly....
10 posts in this topic
Seen this happen on someone’s Sherco before and now happening on my Trs...
When giving it a really big handful, rather than shutting off straight away when I shut the throttle off it keeps revving for a split second or so and then revs down... almost like the vibration of the bike is causing to rev.
Happens most when bike is stationary and I rev it to clear it out....
Any ideas anyone?
Share this post
Link to post
Air leak on inlet..... start the engine and spray WD40 or similar around the inlet area and see if the engine note changes.
Share this post
Link to post
Just a point of curiosity; do you find that you need to "rev it to clear it out"? I have had three TRS bikes, two with Dellorto carbs, and one with a Keihin carb, none required clearing out once the carbs were adjusted for the local conditions.
You may want to pull the plug just after clearing it out, and check the colour to ensure that it is not running lean which can cause the run-on.
Spencer
Share this post
Link to post
Spencer
Curious why you have had three TRS already, one of each displacement or did you wear them out?
Share this post
Link to post
I started with a 2016 280, bone stock which I really liked, then out of curiosity went to a 300, added a Reiger shock and the Keihin carb. Decided that I liked the 280 better, so I got another 280 and transferred the shock and carb over to it as they are great upgrades. All of the RR models were sold out in Canada so could not get one in a 280cc size. The last 280 is a 2017. The only thing that I have worn out is the tire on the 300; great bikes.
Spencer
Share this post
Link to post
Might just be the throttle cable needs lubricating,  I've had that on lots of bikes.
2 people like this
Share this post
Link to post
Talking about Keihin only here from experience.  If the carb spring is biting into the top cap and you don't reassemble with the slide inline then some sideways force can be applied to the slide. It then tends to stick a bit to the body slowing the return to shut. Check cable also as if one strand is split it can catch and do similar things. Had two cables do this over 10 years of riding.
1 person likes this
Share this post
Link to post
A blocked pilot jet can cause the engine to over run when closing the throttle.  Does not seem logical but it can.  Worth checking.
Stuart
Share this post
Link to post
Spencer
No but noticed the issue when revving the bike to check running sweet.
Share this post
Link to post
Cheers for that chaps, I’ll give those ideas a go.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
