Badgravity
New challenges ...
So - long story incredibly short - I have never owned/driven motorcycle and I bought Sherco 290 (2008)
Most of my hobbies have been last 15 Years around radio controlled cars, quadcopters and lately helicopters.
wish me luck :)
Share this post
Link to post
I believe trials riding is the best introduction to off road motorcycle riding you can do.  Established trials riders can go on to be master all forms of off roading, the likes of former British champion Graham Jarvis as a prime example.
Trials riding refines your motorbiking skills, such as balance, throttle control, clutch and brake control learning to feel the bike and reacting to it.... In fact many if not most of the top riders in disciplines like moto x and enduro all train on a trials bike as part of their training routines.
Also the beauty of trials is -  its relatively safe (low speed) and also one of the cheapest forms of motor sport you can do.
My only advice to you would be that a 290cc trials bike can be a handful, especially for a beginner (I'm not trying to put you off) it can just be a bit scary at first (though the 2008 model will be a lot softer than a more modern version). I would probably have recommended you try out something like a 125 - 200 to start with they can be a lot of fun and won't pull your arms off.
Good luck & I hope you have lots of fun riding!!
Share this post
Link to post
Don’t worry BadGravity.  Not all of us will try and get you on a Beta Junior 80.  Always use your lanyard kill-switch. Make sure throttle returns smoothly - and use good-quality gearbox-oil.  Plenty of great people and threads to read on here.   Start with easy stuff , be careful and enjoy.
Share this post
Link to post
Thanks guys for support.
No lanyard kill switch - just a tiny red kill button, also no trial boots yet and pegs are pretty dull and rounded - maybe sharpen them with angle grinder ?
Share this post
Link to post
don't ride without boots - I tried it when I got my bike (before I got boots and I couldn't wait just to ride around the back garden) - its amazing the damage those footpegs can do to your shins - even of they look rounded!!
Share this post
Link to post
http://advrider.com/index.php?threads/lanyard-kill-switches-im-a-convert.1072448/
This guy is worth reading. Clutch and carburetor guru. Note you can easily solder it in tandem with the existing “off”-switch.
My top 3 buys for a new bike are -  S3 Hardrock footpegs.  Apico “shorty” levers , and the Kill-Switch.
Edited by Nebulous
Share this post
Link to post
Yes, grinder or file - you may need to add weld to build up the teeth if badly worn.  Ensure the rests don't droop, ideally they should be just above the horizontal when viewed from front or rear. You can't ride properly if you are trying to stop your feet sliding off angled pegs.
Share this post
Link to post
From my extremely limited experience with trials, a whole 4 hours so far, I found it really hard work but hugely rewarding and loads of fun.
I too recently bought a Trials bike to trian come core skills that I know will be applicable to enduro, dirt in general and road riding.
you think your machine control is good... then you ride a trials bike!
Have fun, try new things and the best part is if you fall off you'll probably only be doing about 5mph.
Share this post
Link to post
Damn this thing is fun but hard ... 30 minutes adjusted carb and researched how petcock works ... then the riding - palms were sore after 15 minutes :)
Also clutch lever ... should be usable with one finger and it is ... just how the hell i do not pinch other fingers - always had to move fingers out of the way and grab the lever.
And thanks guys for holding me up ;)
Share this post
Link to post
You can get Apico “Shorty” levers , that can sit inboard of the grips.  They also do “Bendy” levers that are also quite short.
Share this post
Link to post
Hi there you're clutch should ideally clear before the lever reaches you're spare fingers. you can likely adjust it with some fine tuning but if you're really green get someone who knows there stuff to set it up or it could cost you a clutch.
Neb's right too a shorty lever might be the answer.
Also sounds like you're gripping the bike too tightly, most beginners do this and it takes a bit of time to learn how to relax.
Have fun.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
