Install kill switch on Bultaco Sherpa 250 m-49
Buckyten
Trying to install a simple two wire KS one wire from switch went to ground and  the other is a mystery.   The other wire ?   There is a terminal block that has 8 terminals with 5 being used 1 ground whiteon right side then black going to coil.   then green, black, yellow all on left side of block.  Those 3 are from wire loom from mag/eng..  So where does my other wire from KS go to and how?????  Thanks for helping.  It must be simple right?!!!
