Squeak...
heffergm
That occurred to me. It sounded vaguely like an air leak, which was weird. You think it's the reeds themselves, or something else related to the reed block?
14 minutes ago, reggie said:
From the reed valve .
Compression leaking out, or air squealing in or out from main bearing oil seals possibly. Have you only just noticed this sound?Compression leaking past piston rings as piston movement just stops....could be totally normal. In the quiet, ghetto blaster off, Chris Evans muted (gone would be better) talkative by standers asked to multiply 3.789 X 754.89 in there heads, and no calls from the kitchen about things not working...and you will hear all sorts of noises emitted by your faithful steed. If it were my machine and it worked as good as before the noise noticed then ignore and ride on???Your engine running will utilise the compression increase on igniting the fuel and air and this will force the piston towards the cylinder walls increasing the seal. That’s why when the rings are nipped or gummed up power loss is felt. The only other thing that comes to mind is the water pump seal may be squeaking, I’ve had no end of water pumps that make all sorts of noises straight out of the box. The lube contained in the anti freeze usually helps resolve that issue. Do you still run anti freeze in your bike? Any work done and you may have had tap water put in the cooling system. I always recommend using distilled water pre mixed with the best quality anti freeze you can obtain, less chemicals to attack the aluminium. Hope you can either eliminate this sound by finding the cause or satisfying yourself that it’s nothing wrong.??
So warmed the bike up a few minutes (it doesn't make the sound when completely cold), pulled the plug, and the noise is still there. I'm mystified, mainly because it's impossible to pinpoint where the noise is coming from. I've heard from one person that says that have the same noise, and has continued to ride it with no sign of mechanical issues, so I'm inclined to do the same for the time being. I'll see about getting a mechanics stethoscope to help locate the sound.
  • Confused 1
On 19/07/2018 at 10:49 PM, heffergm said:
By the way @miner, what was the fix? Just pull the flywheel and clean it up?
Yes..... dremmel and some 400 grit paper to finish..... I tried oil in the bottom end, oil in the plug hole, still made it, was taking the casings off to start digging in and saw it.  It was corroded and it was the flywheel squeaking on the coil, had been getting in the pulser coil opening, bottom part of the casing gasket had a bit out of it.... googled it and it appeared to be a thing.
