Just over a month ago I bought a barely used 2004 TXT Pro 300 (not even a single scuff on the bodywork). Anyway, yesterday I was in 6th gear going up a dirt road (gently sloped upward) and after about 1 mile of this the bike died. It basically sputtered and quit. Exhaust smelled a bit funky. Kicked it a few times, nothing. Waited 5 minutes and it fired right up.
I've never had a problem with the bike under normal trials-like conditions (the fan does come on fairly quickly when puttering around in 1st doing obstacles), and this was the first time I took the bike out and bombed up a road at such speed for the distance that I did. So my questions after this experience are:
Is what I experienced just 'normal' overheating?
My concern is if this can happen at 75F in temperate Washington, will I be overheating alot (meaning during slow trials riding) when I take this thing out to eastern Montana at 90F?
Should I be concerned or do anything to the bike?
In the future if this was to occur again, how should I deal with it? (I was worried I'd seize the engine or something if I overheated it and let it sit)
How should I approach long, fast stretches like this if flying through it in 6th can cause problems?
Using 80:1, 100LL Aviation Gas
Yamalube 2-stroke synthetic for gas treatment
350cc of Dextron III ATF for oil
Checked radiator fluid, its a nice green, filled to top of radiator
Thank you for your time.
--Tim
