These forks were only used on the m/y 2000 Rev 3 they are not the same as the forks used on any Techno or Zero . They were made by Paioli. There is not much information available on these forks. Good luck.
If I remember correctly there is a screw and a jam nut that moves the shaft which pushes the clutch push rod up or down this allows different amounts of clutch rod push movement. This means quicker or slower clutch release and also engagement.
I think it would be best for to re-pack the silencer. When the packing gets old it is oil soaked, loses sound deadening and it's thermal insulating properties as well.
The Beta 4t trial throttle is different than any of the " dirt bike " Domino throttles. I believe the only place to purchase the throttle tube is as part of an OEM Beta assembly. There are now 2 Beta 4t throttles 1) the standard one starting with the 2007 Rev 4t which is the same as the standard Evo 4t m/y 2019 and starting with the 2019 Factory model there is now a slightly different ( faster ) one
You can test to see if you have the lanyard switch wired correctly by doing the following. Disconnect the lanyard switch, hook up 2 wires to where the lanyard was hooked up. Now start the bike, once running short these 2 wires together, the bike should now stop running. If the bike does stop running there is something wrong will the lanyard switch.
BETA USD FORKS
in Beta
