eddie_lejeune
Posts posted by eddie_lejeune
  1. Hmm wonder how much that center box is?
    New clothing looks good too!
    Barry the clothing hasnt changed since last yr.
    I will enquire of all the prices and post them here when i get them
  2. Look more closely at the photo and read the script. You will now be able to ride through something deeper than a dog's drinking bowl without drawing in water and blowing the barrel off its flange. Yes, the air inlet is at long last sensibly positioned, something modern frames could always so easily have allowed with their large section frame members.
    I think
    sure if the air inlet was through those vents it would be a disaster to wash. It was a good rant but you spoiled it with that statement
  3. I don't know which year they changed it but one of the things they changed was that the locating peg on the swingarm used to be screwed on but is now welded on so the newer brackets are machined out to sit over the weld.
    Another change may be because the 05-onwards Beta's have a Grimeca rear caliper instead of the old AJP ones.
    I may be wrong but the 01,02,03 Betas may have the same bracket so I would've thought they'd be quite a readily available part.
    Who did you order off because if you're in the UK I would've thought Beta UK will still have them in stock.
    i think this seems right they now have 2 piston caliper on the back also, to think i have had 7 or 8 betas now and i have never had one of these off
  4. ·
    Edited by Eddie_Lejeune
    ... if it needs work, do it!! I take my carb off after every ride to clean it out and therefore my bike runs perfectly every time i use it.
    I took the carb off to set the tangs up and do the mod on the overflow when i first got it home..... or i would have been using a gallon of fuel every 30 minutes!!!! But if you had the overflow problem and choose to leave it like that, that is up to you.
    By the way... the V-Force3 reeds i put on make the bike lovely and crisp. It improves the whole range, lovely and clean from the bottom and revs right through.
    i have an 06 rev 3 and i find it doesnt leak at all, i also have the fly wheel weight off and a quick action throttle on, the factory head i will get this week and im still ****e :D
  5. ·
    Keep loyal to Beta..bought a 280 Pro '06 for my lad at Xmas and had a few problems..fixings are poor quality, air box won't keep a water buffalo out let alone water. Have had to replace cylinder head gasket as oil/water was pi**ing out at med revs (3 bikes have had same problem in our centre). My lad does love riding it however, its just that I wait his every return home expecting to spend hours (and money) putting the bike back together.
    Buy a new Beta.
    things like this put me off a gasser
    When I had my 02 125 gasser it would break easily wuite often, it got to the point where if I came back from a trial and nothing went wrong then I'd be ecstatic
    and this
    If i were you i would stick with Beta. last year my gasser txt 125 2000 had a lot of problems. i ended up having to re build the whole new backwheel because the hub cracked in half
    i dont even have to clean the carb or change the plug on my beta....
  6. Hi all, i have always had betas since 1998, basically im thinking of a change this year, i quite fancy a gasser but have always been of the opinion that they are a pile of ***** in the sense that if you buy one you nearly need to have as many spares for it. With the beta its virtually maintenance free but i feel its now becoming rather heavy and outdated compared to the like of the gassers, let me know what you all think cheers!
