Rub it down as best you can then prime it with plastic primer and then 2 or 3 coats of 2k paint and it will look better than new remember to paint the insides of the mudguards first or it will look s-- t when you build it up
Believe it or not but you can get Chinese copies of a Chinese copy oko .if you got one of the cheapest ones it will never run right .i got one and it had no pilot circuit cast in it
Hi the Cush drives in the back wheel hub of my tlr 200 are shot and wondering if its better to replace them with the original bushes or is it better to make them solid with alli bushes
A decent chain through the frame not the wheels (you can get a security chain through the frame just behind the front sprocket and above the chain on a 4rt) and a ground anchor bolted to the garage floor would be a good investment.
Dont rely on a chain through the frame a 18v cordless grinder with a 1mm disc will go through the very best chain you can buy like butter, spend your time and money on beefing up your shed security i.e. Metal door and bars etc
Watch what oko you buy there is a lot of cheap copy's on eBay .i couldn't get my 200 to carburate right even with a new delarotto and I bought a oko from classic trials and it's been like a Swiss watch ever since
To people that feel that it is not structurally sound may like to take into account that it has been built by John Bliss of Cotswold Motorcycles well known by many for his special builds.....this is not the first conversion he has undertaken. you may like his MAJESTY like Yamaha conversions that have 4t Jailing engines fitted .Chris Koch an excellent rider from the south east owns/owned a Cotswold bike so its probably not the dog that you may think it is.
Google 'Cotswold trials motorcycles images' to see what he builds
Say what you like you can see from the pictures that the Down tubes are replaced with a thin tin structure bolted on to the head with 2 bolts transforming the engine into a stressed member even if the tin survived a jump which I doubt it would your relying on the engine to take it and as hank said they are just cheap junk
Take a closer look at it .the Down tubes have been cut and replaced with thin tin bolted on to the head and there's no bash plate as such .the first time you come off a decent jump it will bend its self like a banana .waste of a good bike why would you .
Just bite the bullet and buy a new master cylinder 80%of the time its the cylinder that's causing the bother not sure if the newer evo one with built in resevoir fits yours
I've ran 70 to 1 fully synthetic in my evo, fantic ,still saw ,law mower ,strimmer, and everything else that's 2stroke for years with no problems and sometimes in 4 strokes too if I've no straight petrol lying about so I don't think it matters as much as most people think
Engine Paint
in Yamaha
2k car paint better than all that heat resistant stuff even for exhaust Down pipes doesn't burn off and a great long lasting finish
