Back Brake
coxy
hi could anyone help me with bleeding my rear brake as im finding it a pain in the a***, could some1 tell me the best way for it to be bled because i cant seem to get all the air out of the system and i have no back brake!
thanks
coxy!
lift the back wheel higher than the fluid cup so the caliper is up high this helps to force any air to the top quicker
or you can syringe the the fluid in from the bleed nipple biggest syringe you can get with a bit of pipe tight to grip the bleed nipple this also works for bleeding the clutch ican send you one if you cant get one
Edited by lepky1972
