Scorpa Flywheel And Timeing
godzilla
I have decided to put a heavier tyz flywheel on my sy racing to help give me a little more grip over the winter, would you recomend retarding the ignition to go with the heavy flywheel or should i leave it advanced? have meny of you changed the flywheel weight and what are your opinions, i ride mostly slippy tight sections and find sometimes the bike gets away with its self. I currently run a 2.8 but i also have a 3.2 that i will be fitting on friday.. cheers GODZILLA..
Edited by godzilla
Hi bud. just taken 60grams off mine and rode a trial at the weekend,Couldnt get any grip at all on the frozen ground.Although no one else found any iether,the legendary scorpa grip was simply GONE. dont know if it was down to the lightened fly but im sure a standard weight would have helped. If you have two you may as well try it.
