95 Jt25 Exhaust Rubing Through ....... Any Help For Newbie
goreboy
This is a problem with all the JTs I ever had. You can usually bend it out but I crash a lot and it always went back to rubbing. I had a patch welded on the inside of the silencer that I'm guessing was a bit thicker than the metal that the silencer is made of, still rubbed but never went through. I've seen guys rivet a patch on which allows for a quick change if it does wear out. Trick to that is getting it bent right so it doesn't reduce clearance. It was really nice when they went to the welded one piece exhaust ('07 I think?) haven't had it move a bit although I did have to space it out as it was rubbing right out of the crate.
