Clutch set up
b40rt
Hi all, got a good second hand clutch centre from MartinM (thanks) have put in 3 soft + 3 medium springs along with a 3 way lever
Haven't had a proper chance to try it yet but is one finger light, and doesn't seem to slip until 5/6th gear if you drop the clutch.
I have removed any ridges on the clutch basket, but read on here somewhere about setting up the adjustment screw on the thrust bearing, but now cant find the info, so would appreciate pointing in the right direction.
Thanks
Ross
  • 3 months later...
Hi Ross,
The guy that owned my tl320 before me used barnett plates and valve springs from a XR600 or 650. With a lubed venhil cable and magura levers - it isnt ty175 light but **** its better than another stock clutch ive tried.
No slip in 4,5,6 either...
Mark
Hi Mark
Prepared to live with it slipping a bit in higher gears, just have to wait for the clutch to bite.
Well worth it for a 1 finger clutch. I have a selection of clutch springs so may swap them later.
Just info on setting up the adjuster required. Anybody ?
Ross
