315r condrod kit/crank
montyhack
Hi all hope someone can help ,I have a 97 montesa cota 315r which I'am trying to rebuild the engine on I can get all the parts except a conrod kit.Apparently honda only supply a full crank at god knows how much!!!
Has anyone rebuilt one themselves or know someone who can? I've heard the engine is similar/the same as a cr 250, is it ?
ANY HELP WELCOME thanks in advance Kev
Hi ,
no the engine is not the same or even similar to the cr250,
you shouldnt have problems with parts try sandifords honda/montesa or pidcocks honda :thumbup:
Hi ,
So was it just an urban myth that the cr250 had the same 315 bottom end?
i think the the clutch plates from one of the MX bikes fitted, maybe people jumped to a conclusion from that ?
I think Honda only sell cranks for the MX bikes from memory but you can probably get aftermarket con rods, hopefully one will fit the 315 ?
I thought that was quite cheap! in comparison the sherco 250/290 crank is £486
That's because your a time traveler, where everything is more expensive in the future !
You need to adjust you clock, or TC does.
Edited by B40RT
