Stationary balancing on rear wheel
drroot
Start out by trying the technique on a small hill as this will help to begin with and just try using your throttle back brake and clutch to keep the front wheel in the air whilst moving up the hill and keep stopping. Once youve mastered that you can move on to doing the same but then compressing and releasing your suspension so that you begin hopping rather than just wheelying. Once youve mastered that you'll find that doing it on a flat surface etc should be fairly easy to do. I dont think that its a technique that is really required unless you are doing some pretty hard trials.
  • 6 months later...
