Gas Gas 2011
alvin123
Think you'll find that's it chap, just give the spindle a tap from the calliper side and it will slide out.
Have a look at picture 10 here: http://www.trialspartsusa.com/manuals/despiece_txt_pro_2011.pdf
That should do it. Just be careful as the axle is aluminum. It's kind of a weird size, just slightly smaller than a 16mm Allen socket.
If you run into unusual Allens like this one, you can make an "emergency" Allen wrench by fitting a nut that just fits into the Allen hole with a short piece of fuel line so that it will slightly protrude from a socket. That will get you by until you get the correct one.
Jon
  • 2 months later...
