349 Cota Rebuild Specifications.
kombivan
Hello Folks
I have a 1979 349 Montesa Cota that I am going to get the engine rebuilt and as there are no workshop manuals for these can you guys tell me things like piston clearence, cylinder head tensions, casing bolt tensions, and anything else that you know about like Firing position, point gap, well i'll leave it to you guys keep the info coming as I am sure others will use it as well thank you.
Kombivan, I have pulled out a very old montesa cota 247 service manual and full parts diagram / numbers manual. It is probably useless to you but the head nuts are 14.5 ft-lbs to 18 ft-lbs the cylinder nuts are 22 ft-lbs to 25.5 ft-lbs
The crankshaft pinion nut is 58 ft-lbs
The magneto flywheel nut is 65.25 ft-lbs
The clutchplate nut is 14.5 to 18 ft-lbs
The counter sprocket nut is 58 ft-lbs
John
Edited by jfc
Thank You has anyone anymore info I am particulally interested in the tension for the casing bolts with the rubber seals. also what is the origional sproket ratio.
Also type of spark plug. Wiring Diagran for 1979 349 cota also are the statos for 247 and 349 the same
i know the cam on the flywheel is different.
Kombivan, I have had the same problems finding information. If you PM me I can send you a PDF of a manual with all the torque settings, oils and quantities and factory specs for the bike. Or you could visit todotrial.com and download the manual. It is actually for the 349/4 but from what I can see most parts are common. Oh, its in Spanish, but the important stuff is in English too.
Andrew
I don't think the translation would be that important. It is basically a full owner manual with a parts book etc. I've been able to get the info that I wanted and I can't speak Spanish at all! Rather than putting your email address up for all to see, if you send me a personal message (an option on the drop down menu by your user name) I will forward the file to you. Or as I said in my previous post you could visit todotrial.com and downlod the manual in PDF format.
Andrew
Engine
Cycle / 2 stroke
Cylinder / one
Bore / 83.4mm
Capacity / 349.6cc
Compression ratio / 8. 5: 1
Ignition
Altinator / Motoplat
Points gap / 0.4mm / 0.0157inch
spark Advance before TDC 2.7mm /1.05inch
Spark Plug
NGK / NGK BP-5ES
Bosch Theormic grade / 160 + 175
Electrode Gap / 0.5mm / 0.0216inch
Thread 14M x 1.25 x 19
Carburettor
Make / Amal
Type / L-2627/215
Diffuser diameter / 27
Main Jet / 145
Low speed Jet / 20
Gas Valve / No4
Sprayer / 107
Position Needle / 2a (2B1)
Adjustments and Tightening Torque
Miniumn Diametral clearence between pistion and Cylinder 0.045mm / 0.0018inch
Maxiumn whipping crankshaft ends mounted on the crankcase / 0.030mm / 0.0012inch
Recomended Tightening Torque
Cylinder Fixing nuts / 2 - 2.5 m.kp / 14.5 - 18 ft lbs.
Cylinder head fixing Nuts / 3 - 3.5 m.kp. / 22 - 22.5 ft lbs.
Crankshaft pinion nut / 8 m.kp. / 58 ft. lbs.
Magneto Flywheel nut / 12 m.kp. / 87 ft. lbs.
Clutch plate Nut 2 - 2.5 m.kp / 14.5 - 18 ft.lbs.
Main Crankshaft Bearings 25x52x15 / bearing Number 6205 / C3 C3 having correct clearences
We still don't have the tension for the casing Bolts for the centre casing with the rubber o-rings anyone know this tension?
Edited by kombivan
Sproket Ratio
Counter Sproker / 10 teeth
rear hub sproket / 40 teeth
Chain pitch / 15.875mm /5/8inch
Roller Diameter 10.16mm / 0.400"
Face between plates / 6.48mm / 0.255"
Primary Drive
Pinion Crankshaft / 20 teeth
Clutch Toothed gear / 64 teeth
Transmission Ratio / 3.20
Gearbox 6 speed.
Wheels
Front / wm1 / 1.6 ...Trial......2.25" X 21"
Rear / wm2 / 1.85....Trial.....4.00" x 18"
  • 1 month later...
Hi everyone,
I have my Cota 349 engine on the workbench because the magneto side main bearing has some slight up and down play. I've never worked on a two stroke before and this is the first time I've seen main bearings installed from the outside of the crankcase. It appears as if a new bearing could be installed without splitting the cases IF the old bearing could be removed. I wonder if any of you has tried it.
regards,
Dalton
  • 1 year later...
Hello I'm back, I dropped my 349 off for the engine rebuild a couple of weeks ago then when its finished I have another 349 to start on. My back had been giving me a hard time but looks like I will soon be back on a bike frame is getting powercoated have new tank new guards new everything been polishing up the wheels be off to the respoke girl this week. Won't know myself had both of these cots for 10 years collecting the bits and pieces to get them back to their glory.
