Beta Techno 250 Cooling Fan Not Working
le3458
i have bought a beta techno 250 recently and noticed the fan does not work. i have put a 12v battery to the fan ,and it spins over nicely i have tried bypassing the temp sensor and still does not work. any ideas? thanks
Used to have a 98 techno and had similar issue. If after bypassing the thermostat the fan still doesn't work then your fan regulator will likely be the culprit. It's a small black box mounted under the seat as I remember. Goes without saying but check for loose interconnecting cables before replacing the regulator.
