200 Cota Carburettor
29markt
Hi,
Could anyone put me straight on the correct carburettor for my 200 Cota? It has a Amal L2624/402 (26mm) fitted, and the spec sheet it states it should have Amal L-720 (20mm)????
Could this be contrutibutory to it not bleedin' starting!!!
Best bet is to replace it with a Mikuni or I like the Dellorto jetted for a GasGas 125. The dellorto gives sharper pick up compared to the Mikuni ( not sharp compared to a modern bike!).
The 200 came with both mark 1 and mark 2 concetrics, yours is the mark 2.
ian
Thanks Ian,
In Motion do the MIKUNI dont they?, is the one i have correct for my mode? l, as may service if the right one.
ian
If I'm not mistaken, there were two Cota 200 series. The first one used an (strange) Amal 720 and the second one the L2624/402.
You'll need these jets:
135 Main
20 pilot
106 Needle jet
2B1 needle
and a number 3 cutaway for the throttle slide.
You should also change the o rings of the screws.
135 Main
20 pilot
106 Needle jet
2B1 needle
Thanks kingscorpian, said bits ordered from amal today, new airfilter, hope to be running for the weekend!! ;)
