2014 300St Airbox
magsy
Hi can anyone tell me if theres a knack to refitting the airbox on this bike. Its only as I've had to remove the carb several times recently that its become a real pain. There must be an easier way than grappling for ten minutes with a screw driver. In the end I removed the fuel tank which gave me much more room. I know manufacturers are looking for new ways to improve there products but this to me is a part that needs to be removed often and so should be much simpler to fit. Any thoughts most welcome.
  • 3 months later...
Just be glad you do not have a 250 with dellorto and the rubber reducer ring.
Ant idea which way the rubber reducing ring should go? I guess the alignment mark at the top facing away from the carb!
