Tech Folks Oil Capacity
mrorange
According to the 2015 Montesa manual, the Tech forks area as follows
Specified fluid (left and right): Tech OJ-01 (SAE 5)
Oil capacity (left and right): 400ml
Standard oil level (left and right): 50mm from top of tube
(Edit: 75mm for the Gas Gas with aluminium Tech forks)
The oil capacity shown is after a complete dismantling of the components. You would remove substantially less than that when doing a simple change. The important thing is to set the level correctly.
If this is for a 2015 Montesa then you should have got a proper owners/service manual with the bike and it covers both the Tech and Showa forks. If it is for a Gas Gas then this advice may not be accurate as there are a number of different versions of the Tech forks out there.
Chris
Brisbane Australia.
Edited by aussiechris
