Wheel Run-Out
monty_jon
In which direction?
To the side or on height?
A sidewise run out of 1mm is still Ok, while 3mm is too much.
A run out to height here also 1mm is OK, tires have already a run out of 1 - 2mm, a good workshop will mount the tire so that the run out of rim and tire will be compensated to each other.
Anyway as it is a trials bike I guess there are not so high standards as you can't ride very fast as with a road bike.
So a rum out of 2-3mm might still acceptable in both directions. I personal don't like it and gave the wheels of my old bikes to a professional "Radspannerei" that trued them, a small amount of bucks and as they too check the tension of the spokes worth to spend,(10 € per wheel). I gave them just the wheels and axles to save money.
