Montesa 4Rt Rear Spring Upgrade
mrorange
I have a standard 2015 4rt and would like to upgrade the rear shock spring as I weigh 102 kg
I have from a previous beta Evo a heavy duty spring which is the same diameter as the Montesa but is 13 mm longer however the standard spring was wound up around 15 mm so would there be any reason why the longer spring would not work if not wound up to same length as previous
It's not just about length, you need to know if the spring rates are different otherwise it could go coil bound and lock out before hitting the bump stops.
I'd recommend fitting a firmer spring though. I'm the same weight as you and fitted on to my 260 repsol and it made a great improvement, I wish I'd fitted one to my previous 4rts.
