Top Speed Ossa Tr 300I?
caseih
You need an enduro bike. Trials bikes do not like roads.
no i don´t.i have had both endurobikes and motorcross so i know what i want.
I already have a trial and im perfectly satisfied with it now, just want a newer one.
  • 2 months later...
Just today tested with a accurate GPS, OSSA TR280i with Termignoni and EVO6 (for Termignoni) map top speed: 92 kph.
I have 9T sprocket front and 42T rear, so it's pretty high-geared, and loads of power left, just like it needs another gear. I'm guess if I put the 11T in front it'll be between 110-130 kph tops.
TRi 6th gear is very nicely overdrived for transit "cruising" and my tests show it can cruise 70-80kph all day, but as said, trials bikes do not like roads, I'm using it just for occasional connecting streches between playgrounds and also helps to burn and clean out the exhaust going full in 6th gear :)
