Beta Help
markb21162
Hi m8 there is some plugs on the loom and some cut off AV got a plug from the magneto then there is a brown/white wire and a red/white the there is a plug on the cdi then there is a single blue wire there is no plug on the coil it's got a black and a black/white then AV got a wee box which has a single yellow wire then there is the fan there is a green wire that comes from the thermostat that a think is an earth then a yellow wire hope that all makes sense thanks mark
Edited by markb21162
Blue from CDI goes to frame / earth.  Yellow lead from box connects to yellow from stator,( another yellow is split from this to power the fan circuit )  one kill switch wire goes to red / white the other goes to frame / earth
