Beta Evo Fan Stopped Working?
mickmc
hi  the fan stopped working today on our beta evo 125, i don't have a voltage tester so
could i test it with a car battery, to see if the fan is working and that it isn't the thermostat, would that be the correct voltage ??
thanks
Put the two thermostat wires together then start it up. If the fan spins it'll be the thermostat. If it doesn't it may be the fan, but try a test bulb to the thermostat supply wire first (better than a meter as it'll show if the supply has enough guts to run the fan).
