Flywheel Weight ?
andyjohnson_10850
I think the TRS has a "crankshaft" bearing in the flywheel case. This may make fitting a weight a bit trickier than usual.
Lower compression? Smaller bore carb? Reduce the diameter of the exhaust either at the engine or tailpipe using an insert?
  • 4 months later...
  • 1 year later...
  • 4 months later...
