Best Way To Mount A Number Board?
dowsonm
The map button and two LEDs are just held in place with silicone, they just pop out of the original mount.
I made a bracket out of an right angled piece of plastic (made from the edge of an old plastic box), drilled out holes along the top for the button and LEDs.
I think the button is around 11 or 12mm and the LED's 4mm.
I hot glued them in to the new bracket from underneath and used a couple of small, counter sunk bolts and nuts to bolt it to the back of a normal number board, close to the top edge.
Used a black number board, black plastic and black counter sunk bolts, so it all looks rather neat. (well it would have if I managed to get the bolt head level!)
The map button's body isn't totally round, there are a couple of lugs either side to stop it rotating in the hole, just needed to carefully file out two slots in the hole to make it fit flush.
Edited by goudrons
