Carb Problem Fantic 305
fantic tom
I'm having some bother with my fantic 305, it will only run with the choke on. With choke off it runs up and down and and soot up the spark plug. Iv stripped and cleaned the carb and took off the reed valve and checked them and all looks good! The manifold lookx good too no ctacks ect. Any ideas what else I could check? Cheers!
are you sure the pilot jet is ok? if there is the genuine dellorto carb fitted, it'd have a 2nd slow jet and circuit in the bowl. is this circuit ok?
  • 1 month later...
