OSSA mar engine rebuild questions
biffco
Following the last trail I did, I now unfortunately have a crack between the sump plug hole and the case edge.
I assume the only way to fix this will be to strip the engine and get it welded ?!
With this in mind what parts at a bare minimum will I require ( seals, gaskets, bearing etc...)
I don't know anything about the history of the engine, the power seems ok ( though I have never rode another MAR to compare it to), but whilst it's apart what else would you suggest I consider doing to it ?
On the same trial that I cracked it, it started slipping out of first gear and going to neutral. I have re-ground a better point on to the detent pin which has improved it.
Again whilst I have the thing in bits,  is there anything else I should consider replacing to improve the gear selection ?
These are photos of the cracked sump and of the  piston and bore looking through the exhaust port.
