Does this sound right
Tomfarmer
 You can get it done pretty cheap. Main bearings, main seals, center case gasket, base gasket and intake gasket. Buy the bearings from a bearing supply. Beta used to have a gasket and seal set. Good luck. Cheaper if you just take the engine alone to a shop.
