Beta Volt regulator rectifier
Gazbee123
Hi all purchased a regulator could you tell me if the yellow wire need power to it please there is 5 in total two for the fan two for the thermostat and one left YELLOW ? Is it for the front light or should a wire be connected I took the old part off today yellow wasn’t connected fan won’t work unless I put battery on it fitted new part still won’t work even bypassing the thermostat doesn’t help kind regards
Edited by Gazbee123
More info
Hi thanks for the reply so the regulator bolts to the frame to act as an earth I’ve done that .. and the yellow wire in the picture is connected to the stator wire to give live feed to the regulator ?
Edited by Gazbee123
More info
Interesting, I just had my daughters Beta 80 apart for some tests of the fan and see this post.
It was connected just as Reggie says... yellow is connected and earth grounded on the tab, the others two went to the fan and t-stat.
