tiger cub forks
detective 21
my project currently has some 36mm jap forks in that are not really suitable for trials, I am planning to change to bultaco 35mm leading axle forks as I have access to some, my question is what type of yokes? cubs are non parallel with 1.5 degrees in the yokes as standard, but given that I am changing to leading axle forks should I be looking of parallel yokes to compensate for this change or would non parallel ones work without causing issues to trail/rake?
  • 4 months later...
I recently got a 1961 tiger cub. Unfortunately the front fork comes from a Montesa. I would like to go to scottish pre 65 2 days trial. Which front fork can I get suitable for this trial ? I read something about marzocchi hydraulic fitted into an original forks ?...
Thanks in advanced
Thanks in advanced
If you are not mega rich then most bikes have marzocchi forks with the alloy sliders turned down and fitted into Norton sliders. However when doing this the Marzocchi sliders become VERY thin so best to entrust the work to someone who is experienced at this modification. Gives a good front end when done and as you say is Scottish legal.
Thanks in advanced
Hi Erem,
The 35mm Montesa fork legs from the 1970s Cota bikes are very suitable for your Triumph Cub but ideally need to be fitted into lower fork legs from Triumph, Norton or AS/Matchless these two brands use the same forks.
The lower fork leg from the Montsa is slimmed down to fit into the type of fork you choose either Triumph lower legs which are steel or alloy AJS type then usually a joining piece to make up the gap between the two turned to suit.
Best to find someone to do the machining work who has done this conversion before. If you can make it to the Telford off road show next month there will be people there who do this.
The Triumph lower legs seem much harder to find than either of the other types, they weigh more and are slimmer internally so the donor legs have to be turned to a smaller diameter than needed for the other makes. Both Norton and AJS Matchless lower legs are I think being remanufactured.
I think lots of the alloy lower legs about on autojumble stands were removed and replaced with new due to wear developing causing MOT test failure, this wear is unimportant though when another leg is fitted inside the worn one.
As for yokes my preference would be 1.5 degree run out from these people https://villiersservices.co.uk/index.php?main_page=product_infoandcPath=83andproducts_id=295andzenid=mvt2bentf3hr71lhd9rqguvt24 when using straight leg forks.
For leading axle then parallel might be best but for a British bike unless using Royal Enfield lower legs keep them straight with 1.5 yokes.
Edited by trialsrfun
1 hour ago, trialsrfun said:
Hi Erem,
The lower fork leg from th Montsa is slimmd down to fit into the type of fork you choose then usually a joining piece to make up the gap between the two turned to suit.
Best to find someone to do the machining work who has done this conversion before. If you can make it to the Telford off road show next month there will be people there who do this sot of work.
The Triumph lower legs seem much harder to find than either of the other types they weigh more and are slimmer internally so the donor legs have to be turned to a smaller diameter than needed for the other makes. Both Norton and AJS Matchless lower legs are I think being remanufactured.
I think lots of the alloy lower legs were removed and replaced with new due to wear developing causing mot failure, this wear is unimportant though when another leg is fitted inside the worn one.
As for yokes my preference would be 1.5 degree run out from these people https://villiersservices.co.uk/index.php?main_page=product_infoandcPath=83andproducts_id=295andzenid=mvt2bentf3hr71lhd9rqguvt24 when using straight leg forks, for leading axle then parallel might be best but for a British bike unless using Royal Enfield lower legs keep them straight with 1.5 yokes.
Hopefully the above may help, good luck with your project.
2 hours ago, old trials fanatic said:
One other thing. Leading axle forks on a cub would be a no no for Scotland btw.
They dont even allow 4 bolts only 2 on Triumph fork legs.
OTF I think the Royal Enfield fork bottoms are accepted in Scotland at the two day I have seen them fitted to several bikes there.
  • 4 weeks later...
If Bultaco 199A have had parallel yokes the trail would have increase from 70mm to 90.4mm. Bultaco Sherpa yokes have 1.5 degree rake.
I also have a 199B. It has a steering angle of 27degrees
As far as I know modern bikes have parallel yokes, approx 60mm offset and a steering angle of 20-22degrees. 199A has 24.5degree steering angle and a total offset of approx 80,4mm (result is strange steering)
  • Thanks 1
Please forgive my ignorance... but do you mean it make it 20mm longer between axles?
If you look at the two lines on the left picture posted by Carl you can see that the space at the lower end is greater than at the top this is where the 20mm comes from.
