Trs rr 250 mapping switch and smoking
westygas270
Hi all just wondered what map setting most run there bike on ? Know some people say doesn’t make much difference also what way does the switch go for wet and dry setting ?
Also done two small trials on my new bike had about 3/4 of a can of fuel through it and is smoking when you open it up, I’ve not really had it opened up as small trials and knowntge garage put a lot of oil in a full tank of petrol has anyone had similar ?
TRS recommend only 50cc to 5lts and definitely no more than 60cc
2017 TRS One RR
Keihin PWK28 carburetor (all engine sizes)
Gasoline - Minimum octane USA – 95 (Ethanol content must be 0%) we recommend race gas, no ethanol
Premix ratio – 100:1 (absolutely no richer than 80:1)
Float height – 19mm
Main jet – 125
Needle – JJH (3rd clip position)
Slide size – 3.5
Pilot (slow) jet – 45
Choke (starter) jet – 62
Air screw standard position (factory setting) – 1.5 turns out
Edited by taff_d
