240 coil
midlife
  • 3 weeks later...
Thank you Fourex.
Well, swapped around the wires to no avail.
Used the Ohm meter to measure wires from magneto on the red wire to frame and green wire to frame. No resistance/ continuity on either.
The black wire from the mag did show continuity.
Can anyone confirm or indicate correct readings?
We wonder now if there is a wire, pickup or stator issue????
Any Flywheel removal techniques or pointers?
Thanks
The hand drawn diagram above is correct for wiring the 240 stator to the later type coil. I would suggest taking the flywheel off and checking the stator, the only way to remove the flywheel is with the correct puller.
  • 3 weeks later...
We have spark! After basically rebuilding the whole stator and re-wireing plus new fasteners and a Ducati Energia CDI....we have a nice spark. Now a few fitment issues and she ought to go.
Thanks to all the inputs from all of you!
attached a nice flywheel timing picture
