Wont start
scratcher
Hi guys n Happy new year..  4 Ride...i had a fall the other day bike went down in a stream..theres no water in the air box. Plugs sparking ok. But will only start on easy start thru the airbox...fur a few seconds. Im thinking its a fuel issue...any ideas.
Did you make sure there wasn’t any water in the fuel?
Might also try bypassing the bank angel sensor...  might be shorted and if so wouldn’t let it start and stay running.
Guessing you already tried the full throttle kickstart twice rest.
Good luck.
Yea tried the reset. N ye think the bank sensor could be at fault..its started only fur a few seconds. But in reality i was using body spray not easy start..i will get some EASY START tomoro n give it a go..if i can get it to keep goin n keep sprayin it, it may pull the fuel thru n run on its own. I was thinkin it may have got a bit o water in the fuel some way but a doubt it..tank never went under..
Good luck with that. Hard hats in the Motherwell area, look out for low flying cylinder heads ....
