Gas gas 1991 ? Trials 250
r1chard06
Are you referring to the Aire (air cooled) or the Delta (water-cooled), both are from 91?
The Cylinder head O Rings on the 91 Delta are listed in the original parts book as:
M01619115 80mm x 2.62mm
and M01619110  125mm x 2.62mm
The Aire gasket part number is not listed in the original parts book, but it looks like a paper gasket.
