Tyre
Team 65
1 hour ago, Team 65 said:
Running a 1976 Montesa 348 going to get a new back tyre been offered a once used tubeless Michalin could I use it with a tube or Will I need a tyre designed to take a tube
You can run it with a tube, no problem ??
17 hours ago, b40rt said:
Some / most  akront rims will be ok with a a tubeless Mitch, ime.
Good to know. I had a TY175 and OEM Yamaha rim would not keep a tubless Michelin bead on. I assumed all tube type rims were the same.
  • Thanks 1
If your still using a tube with the tubeless tyre, trimming the bead with a Stanley knife to a profile similar to a tube type tyre will also work. Do this at your own risk.
